A member contacted the headquarters and Michelin does not advise using their LT tires on trailers. As a matter of fact they went on to say that doing so will void the warranty. Many continue to claim the benefits of the "stronger" LT tire out weighs the risks. Apparently it remains a popular option regardless of what the factory is saying.
Old old stories from the RV world what Michelin says when asked a certain question such as asking for a LT tire for direct replacement for ST tires on a trailer. This story has been around for years and refuted time and time again. Michelin XPS Ribs are recommended for commercial trailer service. We run these tires on our trailers in commercial service for 50k-70k miles.
Now if you were to ask Michelin like this posters email stating; (snipped for length)
**In regards to the email you sent stating:
I have a 2006 Montana 5th wheel Trailer that has two 6,000 lb Dexter axles and 4 deluxe aluminum Rims each rated at 3,042 lbs. I would like to install your Michelin XPS® Rib™ LT235/85 R16/E's on this 5th wheel. Will the tires be fully waranteed in this application?
Answer..---------------------------------------------------------------------
We appreciate your request for information regarding the Michelin XPS Rib. The XPS Rib, size LT235/85R16/E, part number 13080 would be a good fitment for your 5th wheel. The tire carries 3042Lbs at 80-psi max pressure. For best pressure recommendation, run at maximum pressure until you can weigh your axles either call or reply to this email for a pressure recommendation.
It is a good application, so there are no warranty issues. Your tires are covered under applicable warranty.
We appreciate your business and thank you for choosing Michelin.
It is our goal to ensure that your issue has been resolved or your question answered to your satisfaction. If we can assist you further, please respond to this email or call us at 1-800-642-4354 (toll free) between 8:00AM and 8:00PM Eastern Time Monday through Friday or between 8:30AM and 4:30PM Eastern Time on Saturday.
Sincerely,
Diana
Consumer Care Department
Certified Michelin Product Expert*** (end of email)
So as we see depending on your agenda we can back Michelin or any LT tire maker into the liability corner with a certain phrased question we can get a not recommended answer.
Or if your looking for the best tire for your trailer that can last 40k-60k miles and 8-10 years of service we can get a positive answer all depending on the question and ones agenda.
