When my trailers need tires, I will install the same tires I have on my truck: LT load range E. I will inflate them according to the load.
IF tires should be inflated to the sidewall pressure, why did Jeep say that the LT Load Range E tires on my '06 Rubicon should be inflated to 33 PSI for normal driving, and 12 to 15 PSI for off-road?
Oh, right, ST tires are "different". Yes, they are, that is why they will be replaced with LT Load Range E if at all possible. Obviously, nobody makes LT tires to fit the little ATV trailer!
