RJsfishin wrote:
Best bet is don't drive in hot weather.
Next best bet is always start w/ max pressure on sidewall, then adjust for treadwear. And if loaded to the max or more, add to the sidewall pressure to keep heat down. Better to have center treadwear than have it come apart. And it will come apart in hot weather if running hot.
Yep, I used to work for a tire shop, I seen it all.
Me ??? Very simple,.... I just don't drive in hot weather, period !
Not driving in hot weather when you live in FL is a bit of a challenge.
