ShinerBock wrote:
N-Trouble wrote:
If all you go by are numbers more power to ya. Crawl up under each truck and you'll see obvious differences that IMO still puts it in 1/2 ton category by todays standards not 15 yrs ago.
Have you ever crawled up under it to see the differences? What parts under there make it a 1/2 ton? The axles? The brakes? The trans? I am not defending the Titan XD, but if are going to call it a 1/2 ton, then you might as well call any GM 2500HD before 2010 a 1/2 ton along with most of the other 250/2500s around that time. Accept it or not, the Titan XD is by definition a 3/4 ton truck while the Titan is a 1/2 ton.
I have been under one while it's been up on a lift, as well as an F250 or two, GM's 2500HD's, and a Dodge 2500 once or twice.
Yes.....the axles......The big 3 have floaters in the rear and the Nissan semi floating. If we are talking definition, when the semi floaters axle snaps, off go's the wheel, and when the floaters axle snaps you keep going. The axle carries the weight on the semi floating, on the floating all the axle does is provide rotational torque, the entire rear end carries the weight. I believe the Nissan has a rear axle weight rating of 4900. I don't know the Dodge or Ford from memory but my GMC is 6200.
Nissan touts a 14" and change diameter rotor, but it stops there. All the big 3 use much more substantial pads and calipers, rotor size non withstanding.
The frame. Much more substantial on the big 3. No comparison can be made on the rest of the driveline or suspension components either from soup to nuts.
Calling them 1/2 ton, 3/4 ton is all outdated terminology going back to the day a 1/2 ton could haul 1000 lbs, and a 3/4 ton could haul 1500. Since my GMC 2500 has a payload of 2835 I guess I could call it a 1-13/32 ton.
