jdc1
May 04, 2020Explorer II
xscoobysnack wrote:
It's a '95 Sportsmen 951. It does have a shore power cord and a switch on the converter to go between 120VAC and 12VDC. I don't believe it has a charger but I'm less concerned about that than pulling power from the truck. That isn't working through the 7 pin connection currently. Thanks all.
Clean the connector real good, both the truck and camper side. Use lithium grease when you are done (works great on my plug-in Prius).
