NRALIFR
May 04, 2020Explorer
What kind of truck? The +12 volt pin on the seven way plug is typically switched so that it’s only energized when the engine is running, and seems like some makes don’t have the fuse installed in the truck from the factory, so you won’t get 12 volts till you put the fuse in.
