Rrliljedahl
Dec 01, 2013Explorer
Truck camper payload question?
I have a truck camper payload question. If this is the wrong forum, I apologize in advance. I also posted this in the truck  forum.
We recently put a deposit down on a flatbed Northstar Escape Pod 900 SD truck camper (9ft x 7 ft) with an estimated dry weight including options to be 2300 pounds.
Additional wet weight will include water (40x8.3=332 lbs), people (275 lbs), LP tanks (2x25=50 lbs), batteries (2x55=110 lbs), plus any food and gear easily adds up to 1200 pounds.
I estimate my payload to be at least 3500 pounds.
My thoughts on truck selection include:
Cab creature comforts so that wife is happy
pre 2007 federal diesel pollution requirements making travel to Mexico easier.
Single rear wheel and 4x4 as we want the ability to go off road.
I found a 2007 Classic GMC 3500 LBZ diesel crew cab 4x4 (I will have to install a flatbed).
70000 miles.
SLT trim level
LBZ Duramax 6.6/Allison 6 speed transmission
Heavy duty trailering package
heavy duty locking rear differential
Transmission cooler
3.73 rear axle ratio
GVWR of of 9900 pounds
GAWR RR 6500 pounds
GAWR FF 4800 pounds
Tires are Michellin P265/75R16 LTX E2 (3400 pounds at 80 PSI).
The dealer says that there is no sticker on the door as to payload capacity of this vehicle but there is a sticker in the glove box stating camper should not exceed 2200 pounds. In cruising the Internet, some suggest that the payload as specified by GMC might be as low as 2800 pounds.
I will have to travel 500 miles to see this vehicle.
Before doing so, I hope to get a couple of questions answered here:
Does anyone know how to find the payload capacity for this vehicle?
If the payload is truly only 2800 pounds, is this truck from a practical standpoint capable of handling this camper? If so, what modifications will need to be made?
I do not want to have a discussion of merits of Ford Versus GM versus Dodge.
Thank you in advance.
70000 miles.
SLT trim level
Transmission cooler
GAWR RR 6500 pounds
GAWR FF 4800 pounds
