Keith_Haw
Apr 29, 2013Explorer
downtheroad wrote:
Keep it simple...don't over think this.
Air the tires to the max for towing as listed on the door jam.
Mine...80 rear 55 front so that's what they get. Using a weight distribution hitch should not change this.
Probably Les just made a mistake.
When I'm not towing or loaded, I sometimes air them down slightly.
Just make sure the tires your running are the recommended tires and rated at that pressure, mine aren't. It had ST's on it instead of the recommended LT tires and are only rated at 55 lbs.
