Lynnmor wrote:
ktmrfs wrote:
Lynnmor wrote:
I use Goodyear Wrangler HT tires:
LT
they may be LRD, but a pretty low capacity for many trailers. they are rated at 2000lbs/tire. But if your in the 6,000-7000lbs or so loaded capacity on the trailer would be a good alternative, with some margin.
They are rated 2096, I used them to replace my 1820 tires. The highest Maxxis tire that fits is 2150, but I wanted USA tires. Since folks on here were saying that 15" LT tires aren't available, I find that is incorrect and these tires are a great replacement for trailers with 3500 lb axles. 1104 more load than what came on the trailer and that ain't "low capacity."
yes, they are a viable alternative for 3500lb axles. but for trailers running 4400 or 5200lb axles, it's either 16" or ST tires.
