Gdetrailer
Oct 09, 2014Explorer III
1wayhighway wrote:
Did you look on the inside of the door or the inside of a cabinet door for a sticker?
Most OLDER trailers never had any sticker inside, I don't think they did that until 2000 perhaps..
Did you check your title?
Not sure about your State but PA puts the unladen weight plus the GVWR information on the title and the annual registration card..
I suspect that 7500 is the GVWR and if you check the axles/rim you will have 5 bolt pattern which would indicate 3,500 lb axles. Combination of tongue and axle weights will equal the 7500 lb GVWR.
If you are wanting the empty weight then weighing the trailer is the only way to find out.
44,071 PostsLatest Activity: Sep 17, 2026
