bkenobi's avatar
bkenobi
TT keeps popping shore breaker
2019 Kodiak Ultra Lite plugged into GFCI outlet from garage. I've had it this way for a few months without issue. We had the power go out last night and when it came back on today I'm having issues plugging the TT in without popping shore breaker. I killed all TT breakers and shore breaker is ok. Turning them on one-by-one the only one causing issues is the one marked "general purpose". I gather this is the inverter which includes all TT 12VDC. I turned the fridge off since I didn't know which it was powered by but no luck.
Any idea what to check? We have had the trailer since spring but it hasn't had much use so not sure of how everything works in this TT. I can talk to the dealership next week but it'd be nice to have some things to check since this seems likely something simple and I'd rather not drag it over there for a simple issue (especially since they'd likely have a 2 month wait to get it in).
EDIT: In case it matters, the TT converter is a WFCO WF-8955PEC. I've seen a couple topics around that discuss bad converters. Is it possible the converter could have failed with a power fluctuation?
  • Just turning off a breaker doesn't isolate the circuit enough to remove a faulty device from tripping a GFCI. You need to unplug, disconnect things like the fridge to check them.
