Bears_Den
Dec 14, 2018Explorer
TT steps
Thinking of swapping out my standard 3 step trailer steps for the 3 step Mor/ryde steps. Has anyone done this mod and if so what are the pros and cons if any? I know they are suppose to be more stable...
DutchmenSport wrote:
Mor/ryde steps:
Cons:
If the outside ground is too low, you have to put blocks under the steps so they have something solid to rest on. You absolutely cannot use them if they are not touching the ground on something solid.
If the ground is too high, you can't adjust them any shorter. What happens, they are not completely "down", so where the steps lap over the threshold of the door, if that is not completely flat, you can't shut the door. (I've not run into this yet, but it is possible).... But I have had the feet adjusted too high and found the door will not shut as the bottom of the door will hit the step frame.
Pros:
They are VERY solid and can hold an incredible amount of weight.
