JRscooby
Mar 10, 2022Explorer II
rookiehookie wrote:JRscooby wrote:Bedlam wrote:
Brake and turn use the same wire to the camper. Most likely it is on the truck end where it combines these lines.
Does not say what truck is. Does it use seperate lamp brake/turn? Might be in the turn signal switch.
The truck is a Chevy 1500 Silverado from 2007. There is only one wire/connection from the truck to the camper, which connects all electrical stuff (charging the house battery of the camper, tail lights etc.)
If it is 1 wire, doing all that stuff, there is some real Harry Potters stuff going on. I think the minimum would be 5. (tail, left turn, right turn, charge, and ground)
If I was there, the first step would be unplug, and check there to make sure all is good on truck.
