marcindy's avatar
marcindy
Underbelly, reuse or replace?
I have an Open Range Light, 310BHS. The cable that opens/closes the grey dump valves has broken (on both grey tanks), and I need to get access to the underside of the trailer to replace. Like many trailers, there is a plastic material/sheet covering up the bottom.
I have read up on this site about how to remove, however, mine (of course) has nails into the frame vs rivets or scews holding it up. I tried to remove a couple and it doesn't look like fun, especially considering how many are there.
Instead of spending a Saturday trying to pull out nails, should I just cut the old Coroplast out, and install new sections from HomeDepot? The material doesn't seem expensive. I'm not doing the full length of the trailer, maybe 15-20ft.
Thanks in advance on opinions on folks who have done this.
