How long can your fridge be off level while in use before it causes permanent damage? I need to park the trailer at the curb and the road is not level. Will it cause much damage if it is out there f...
How off level are you going to be? Facing the front of the fridge, you can typically be off level up to 6 degrees front to back, and 3 degrees left to right (side-to-side) without sustaining any damage.
Or, you can throw your worries to the wind and consider installing an ARP unit.
