ralphnjoann's avatar
ralphnjoann
UPDATE - Diesel Exhaust
Can diesel exhaust kill you like gasoline exhaust does?
I found this with a Google Search:
"Is carbon monoxide a problem with diesel engines? Usually not, although any engine, including diesel, produces CO when combustion is incomplete. Diesel (compression ignition) engines run with an excess of air and often produce less than 1200 ppm CO. When diesel fuel is burned incompletely or when overloaded and over-fueled (rich mixture), diesel engines will produce high concentrations of CO. Diesels usually pollute the air with particulates and nitrogen oxides, not CO."
Source:
http://www3.abe.iastate.edu/human_house/aen206.asp
