PartyMarty wrote:
JJ , if I understand correctly it is your belief that the steel wheel will fail before the rubber tire will fail due to over-inflation . Is that correct ?
no that is not correct, and is not what I said,
but it could be correct with all the dynamic stresses the rim is placed under in use and especially if it is also well beyond it’s designed pressure ratings…
now maybe you can answer the question that were posed with something verifiable…
where did you get the percentages you directly quoted???
If rim PSI ratings are so unimportant,
Explain the rim ratings for the 5 or 6 rims I posted that don’t seem to have any relationship to a tire (because they were sold as a rim, not a tire/wheel)???
explain why they are psi rated at all if you can use any tire and at any pressure you desire???
AND
is it the Maxxis tire that has earned a good reputation that you dislike so much???
or is it the cheer leaders that have had success and show loyalty to a product they believe to be the best in a given category of tires???
not unlike Honda generator and Hensley hitch owners do…
if it’s the cheerleaders please define the term as you see it so it can be discussed intelligently???
if it’s the tire express your disagreements with your reasons and some backup information???
again so it can be discussed intelligently…
and especially,
I would bet you include me in that class of cheerleaders… if so, in all fairness how about backing that up with some facts??? Please???
Your posts opens many more questions that they have answer… but we will leave them alone for now…
That means that there is no downside to using a load range D or load range E in place of a load range C tire .
A higher rating is a higher rating ..:B:B:B
