More2Explore
Jun 03, 2013Explorer
So any advise on how best to inspect a used camper for hidden damage? Suppose this one did not have an obvious crack or a wet spot? How do you thoroughly inspect a used camper? I've noticed on at least two of the campers I've looked at that the sealant along the trim piece joining the horizontal and vertical outside panels often have a black substance? This is the flexible sealant that comes on a roll and they put it under the trim piece before the screws go in squeezing out the sealant and sealing the seam between the two panels. Any way what I'm really after is tips for doing a detailed inspection of a camper to insure I get one with minor or no damage? Any inspection tips???
44,056 PostsLatest Activity: Dec 27, 2025
