bobndot
May 09, 2013Explorer III
http://www.hitchsource.com/torklift-hidden-power-ford-1973-2007-without-battery-box-p-34891.html
If you are finding difficulty locating a place to keep the battery, depending on your vehicle,maybe something like this battery box would work mounted under the truck. I would think a weld shop could also rig you up something if TL doesn't have a model for your truck.
As stated the isolator is used to keep the camper amp draw off the truck battery. The camper will only take power from the camper battery.
44,066 PostsLatest Activity: Jul 25, 2018
