Crown's avatar
Crown
Washing camper
Hello My question is what to use and what not to use to wash the outside of my camper the front is a Fiberglass cap
And the rest is metal
Trying to stay cheap and not have to go buy the exspensive stuff from a camper store
Thanks
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    mleekamp wrote:
    Agree w/ starcraft69. Never use dishsoap on RV or vehicles. They are designed to cut "grease" and coatings. Use a decent car wash soap...about any will do.
    agreed. In a pinch you can use ivory liquid, it isn't near as harsh as other dish soap and isn't as likely to remove any wax etc.
    Dawn is the dish soap often used to remove wax coating before waxing again. Good on dishes, not so good on cars/trucks/trailers.
    And another thing I've found REALLY handy. Griot's garage has two items worth the price.
    1) bug barricade. a spray on coating I use on the front of the truck and the trailer cap. keeps bugs from sticking hard to the paint etc. made to not be an issue to paint or gell coat etc.
    2) Bug and smudge remover. I first hit the front of the truck and trailer cap with soapy water, gets 90% of the bugs off if I use (1). then hit the rest with the bug remover. Makes quick work of cleanup without removing wax or leaving any streaks.
  • If the RV is waxed, I've found that just using water will get most of the dirt off.
    Bugs, tar, etc. takes something a little stronger.
  • Agree w/ starcraft69. Never use dishsoap on RV or vehicles. They are designed to cut "grease" and coatings. Use a decent car wash soap...about any will do.
  • Never use dish soap!!!!!!! it cuts all wax and top coat right off
    If you want to keep it cheap then use cheap car wash from Walmart like blue coral.
    I use Meguiars Washing & Wax
  • I found a mop looking thing at the auto parts store. I was a thick bonnet on a ovalish kind of frame. I doubled up on the bonnet so it was thick enough to reach the bottom of the corrugated siding. For soap I bought a gallon of cheap car wash detergent. Worked well, I could wash the siding of my 26’ trailer in about 30 min or less
