BurbMan
Jan 17, 2018Explorer II
Water Leak, Repair Update Feb 12th
Well, here we go again. Back in 2013 I found a leak that was deteriorating the slide out floor, so I undertook those repairs. I had a thread on here but couldn't find it again to give you a link, but thanks to JBarca and other forum members who helped me tackle that job and get it all back together.
Last spring I noticed a small soft spot just ahead of the slide on the main floor. Unfortunately we were knee-deep in home renovations, so I put a piece of plywood over the soft spot with the goal of fixing it this winter.
Well, it's amazing how fast things go to pot. Here's what I am dealing with now:
we had replaced the floor after the slide repair, but we used the cheap Allure vinyl so it needed to be done again anyway. So I started to dig in to the rot:
What's interesting is that this TT has the enclosed underbelly, so under the 3/4" OSB there is insulation and the Darco wrap. Whaerever the leak was coming from, I took on a lot of water since there was 1/2" of ice sitting on top of the Darco.
An idea of where we are in the trailer, facing front in this pic:
Here we are with the rot mostly dug out
The tarping process begins:
Now to get into it: The white section you see is fiberglas gel coat, it meets at a seam to the gray part which is a steel skirt:
You can see from the way it's put together that the steel inserts to a crimped molding that prevents any water incursion. You can also see the 2x3 floor joist framing that is wrapped in Darco wrap. The floor frame is wrapped in Darco, then the OSB floor is added, then covered in sheet vinyl, then walls screwed on to that.
So here is the money pic and where I need some help. If you recall from the inside pics, the OSB floor absorbed water right in front of the slide. Here is the pic from the outside with her skirt off, you can see the rot in the floor. However, I cut out a few inches of the styrofoam insulation and the wall in bone dry, so it's NOT coming from above.
The 2x3 framing is wet all along but no signs of water above.
So for the guru's on the forum, where is the water coming in???
Doesn't look like the roof or any windows or appliances. How would I be getting enough water in this spot to cause damage?!?!?!
All ideas and thoughts welcome.
