tpprepper's avatar
tpprepper
Water Line Replacement
It seems that I did not get all of the water out of the main water lines last fall. Found the main 1/2" lines cracked and useless. I am going to replace them but was wondering if there was a "better" line to use instead.
The factory lines are the standard pvc type with glued fittings.
Is there a flex line that could be used?
Hope somebody out there had some experience with this.
Thanks
Vic
  • OK OK OK. PEX it is. Looks like you guys all agree and that's good enough for me. The specs look good, heading to the store.
    Thanks all
    Vic
  • RinconVTR wrote:
    WoodGlue wrote:
    I agree, PEX is best. There are a couple of things to watch out for and they're listed on this page:
    Pex - Pluses and Minuses
    PEX does expand and contract and are much more forgiving as water lines!
    WoodGlue
    Spent the night this weekend with nights of 40ish. Had to turn off the pump switch because of a leak somewhere. In the morning I find drips under the sink where the city water inlet meets the sink feed and quick disconnect feed, only for all drips to disappear as the temps rose.
    And would you look at this craziness...how many excess joints can you count? (ignore the disconnected quick connect...I was narrowing down leak points) COME ON GULFSTREAM.
    I think this means I need to redo the PEX joints and eliminate a bunch of others. Buying the required PEX tools (cutter, crimper) is an unexpected expense, but probably worth having in the tool box!
    Oh my, your cool handiwork rivals that of an M.C. Escher drawing:
    WoodGlue
  • I agree, PEX is best. There are a couple of things to watch out for and they're listed on this page:
    WoodGlue
  • Most manufactures now use PEX. A selection of tubing and fittings can be found at Lowes and Home Depot. Try to find a knowledgeable clerk and talk to them.
  • Pex is the way to go......also check out Sharkbite fittings, easy to work with......
