laidback
Jul 08, 2014Explorer
water pump?
The water pump seems to run constantly in our '14 Cougar... 15 minutes before I shut it off.
Any ideas why?
Any ideas why?
RoyB wrote:
Also assuming you are aware that the water pump is not necessary to be ON if you are connected to CITY WATER. The city water will pressure up your water system.
I only use my on-board water pump to pressure up my water system when I have water in the fresh water tank. My water pump inlet has no connection to the city water connection.
I leave my WATER PUMP switch in the OFF position unless I am off the power grid and have water in my fresh water tank.
This is a simplified drawing of a typical water flow setup...
Roy Ken
laidback wrote:
Yeah....spits like crazy, I bet its air
I'm going to try and let the faucet run and see what happens
sacmarata wrote:
If left on mine will run for just a second about once every 20 minutes. Always suspected a leak but can't find a thing. I assume it must be air????
Hope you figure yours out as well.
