sncraig's avatar
sncraig
WD hitch or not
I am looking into buying a new TT and can't decide if I need a WD hitch. We have had two 35'+ 5th wheels over the past few years and pull with 2011 F250 diesel with rear air bags I added. So my question is now that I am moving back to a TT that will be 37', 1200# tongue weight and 10000#+ GVW do I need a WD Hitch or not. I know I can level the ride out using my bags very easy and the truck can pull and stop this unit nicely. Is there a need to use a WD hitch. Is anyone towing a set up like this.
Looking to buy a 2016 Grand Design 313RLTS.
  • MM49 wrote:
    You probably don't need a WD hitch. I'm pulling a 30' TT with 1204lb TW. I also have electronic sway control. You should have few problems with the rear suspension. Give it a try.
    MM49
    You should know that your "electronic sway control" does nothing while your driving down the road unless you have a sway situation that is so bad that the computer thinks your going to crash. And then the only action it takes is to fully stop the truck - not make minor adjustments to maintain control. It's not an active system that replaces a WDH (though the way it's marketed certainly leads one to assume so).
    BTW, you would be shocked how much nicer towing is with a WDH.
  • You probably don't need a WD hitch. I'm pulling a 30' TT with 1204lb TW. I also have electronic sway control. You should have few problems with the rear suspension. Give it a try.
    MM49
  • newman fulltimer wrote:
    you need one for the purpose of sway control look at the new Anderson chain sway control hitch
    I would not even consider the Anderson for that size trailer.
  • um.... no brainer! For that size camper ... yes!
    I've got WD on my 3500 towing an 8000 pound trailer! Won't leave home without it! I don't care what brand of truck it is, get the WDH with a trailer that long and tongue weight that heavy.
  • Doesn't Ford "require" one with those weights? Check your Owner's Manual, I imagine they do.
  • And you need one because your receiver is probably not rated to carry 1200 lbs without WD.
  • you need one for the purpose of sway control look at the new Anderson chain sway control hitch
