I would like to get some input on a WD hitch. I have a 25' TT and 1999 Dodge Ram 1500 pickup. I would like to know if it is worth the expense to get a WD hitch. I have been towing my TT without one si...
Part of your instability is lost weight off your front axle. The slightest movement of the steering wheel, even subconscious hand movement, will cause the trailer to wiggle. You may also have your headlights pointing in the air, giving you less nighttime vision, and annoying other drivers.
A weight distribution hitch, would restore some of that weight, help to level out your truck / trailer combination, and reduce the bouncing.
