I would like to get some input on a WD hitch. I have a 25' TT and 1999 Dodge Ram 1500 pickup. I would like to know if it is worth the expense to get a WD hitch. I have been towing my TT without one si...
Check your truck's owner manual if you still have it as well as the receiver mounted to your truck. I expect one or both to list two sets of weight ratings, onw with WDH and one without. Typically, that is in the 500-600 pounds of TW range. I cannot imagine a loaded 25' TT to have less than 600 pounds of TW. So you probably need one.
Also, at 600 pounds of dead TW, you lose about 300 pounds off the front axle. That is enough to affect steering and handling.
