monkey44Nomad IIFeb 05, 2021WD hitch?IF you have a WD hitch installed, should it be adjusted with the fully loaded trailer on the hitch, or does that matter.
rexlionExplorerFeb 05, 2021Depends on the brand. With an Equal-i-zer, you set it up (adjusting for proper height and stuff) while unhooked, and if you measured correctly there is no need to adjust anything when you hook up.
Related ContentNew Andersen WD hitchAndersen WD hitch thoughts?WD Hitch or not?Thoughts on WD hitch needRV without a WD hitch
