work2much
Apr 19, 2017Explorer
We weighed everything today.
Truck and camper in sig:
Truck without tailgate, 1/4 tank, no passengers. 8740 pounds. This was the tare weight I needed to DMV the truck. Unfortunately it didn't give individual axle weights and I have to extrapolate a bit to figure truck camper weight.
Truck/TC with 2 passengers full fuel, full propane, packed and ready to go. empty holding tanks. 10 gallons fresh water. 13,700 pounds. 300 pounds under GVWR.
Steer axle: 5300 pounds 700 pounds under axle/tire
Drive axle 8400 pounds. 1,350 pounds under axle.
Adding the weights of 2 passengers and fuel I believe our tare weight would have been an additional 600 pounds or about 9,340 pounds.
So it seems our AF1150 weighs roughly 4,360 pounds as weighed or about 4,700 pounds full of water. That is quite a bit less than I thought even after removing the generator and AC unit.
My old truck was a 2004 Dodge Ram 4x4 dually I was bit concerned about how the 2017 would handle the TC with the factory air suspension. The old truck was modified with air bags, sway bar, better shocks, better tires.
I have to say after giving the new truck an extended drive through the hills and some not so great roads...the new truck killed it. Much less sway, even stock. The factor air bags work great. The truck lowers down just about 1-1/2 " right on to the over load spring with is fairly thick and seems to mitigate sway very well. All the extra power and auto transmission is very nice. Also having the engine brake makes steep downhills a breeze.
We will be hitting the road to Alaska in a few days, so the real test lies ahead. :C
