towpro's avatar
towpro
weight advice
we have a 2015 Ram 3500 tradesman addition dually 4x4 crew cab long bed. Cummins, Aisin trans. Torqlift steel tie down system.
GVWR is 14,000 lbs.
following info from Ram Body builders guide:
empty weight 8319 lbs.
payload 5680
max camper 4581
Only thing I have added is Big Wig sway bar.
weight inside the truck is just the Wife and I.
Currently we have a wolf creek 840.
we tow a 7x14 box trailer with a motorcycle in it. Toung weight is? (2 people can pick it up)
anyway, we are looking at a Artic Fox 996.
Truck camper mag has some figures.
Dry weight 3934 with mandatory option pack (plus we will add AC 200w solar and our brand new memory foam will replace stock mattresses)
Wet weight *Arctic Fox 996: dry weight, 3,934 pounds + 53 gallons fresh, 442 pounds + 6 gallon full hot water heater, 50 pounds + 2x 30-pound full propane tanks, 54 pounds + 2 batteries, 130 pounds + stuff, 500 pounds = 5,110 pounds
Currently my truck still sits 1" higher in back than front with Wolf creek and trailer hooked up.
Will my truck still be OK without modifications and teh 996? On paper its only 1500 lbs more than WC
Currently my truck still sits 1" higher in back than front with Wolf creek and trailer hooked up. would love to be level so I don't always need blocks under front tires on level ground. Maybe 1500 lbs would do the trick :).
