kfballer22's avatar
kfballer22
Weight Capacity HELP. GVWR??? 2008 GMC Yukon Denali XL 2WD
Help! We are getting conflicting information from the dealers we have been visiting, and the responses on RV.net. So we need your help. We own a 2008GMC Yukon Denali XL 2WD. The towing capacity is 8000lbs and we are looking at travel trailers that are at or around the Dry weight of 6000-6500lbs. We have been told that our vehicle would be fine to pull a TT of this size with no issues. We have 2 6 yr olds and having the double bunk bed and queen are preferred for our camping travels.
I need for someone out there who has this vehicle and tows TT to chime in. What should be our concern when we are purchasing our first TT? Our goal is to start out camping in the SE US and eventually take our TT out West for extended periods of time. So imagine hills, valleys, mountains, etc. at some point down the road with this TT. The information that would be most helpful would be a list of specific models of TT that we can research that fit our requirements and weight limits. However, any input is helpful.
Please help. Thanks.
  • kfballer22 wrote:
    Weight Information
    Curb Weight - Front (lbs)2923
    Gross Axle Wt Rating - Front (lbs)3600
    Gross Combined Wt Rating (lbs)14000
    Curb Weight - Rear (lbs)2672
    Gross Axle Wt Rating - Rear (lbs)4200
    Gross Vehicle Weight Rating Cap (lbs)7400
    I can't find "payload" reference in any of my research on my vehicle. Does the above information help? Can I tow a trailer that is dry weight of 5900lbs with this vehicle?
    Was this information found online ?
    If so, it is inaccurate for your needs. The information you need is on the vehicle stickers. When found, that information reflects "as built"
    meaning your specific rig. Look on the drivers door jamb & in the glove box for that info. You should find defined weights & the type of tires that came on it new. Does it have a "factory" tow package ?
  • kfballer22 wrote:
    Weight Information
    Curb weight front and rear=5595lbs
    GVW is 7400lbs, that leaves 1805 for payload.
    Those are probably optimistic numbers.
    Even so now subtract you, the wife and the kids from the 1805 payload.
    Now what else is in the Tahoe? That's what you have left for the TT's tongue weight.
    You really need to load up the Tahoe and go weigh it. Then subtract that number from the 7400 GVW and that's what you have left for tongue weight.
    JMO but a TT that weighs 6000lbs fully loaded would be the max I'd want to tow. That would put the tongue weight around 750lbs.
    A dry (sticker on TT) weight of 5000lbs for a TT would be the place to start. Don't go off brochures, they can be close but normally aren't and can be anywhere from 200-700lbs low. That brochure dry weight on a 5000lb TT could well be 5500lbs when delivered. Best thing to do is pound the pavement at dealers looking at floor plans and stickered weights. 99% of the time the sticker is on the entry door.
    Another way to look at the numbers is you have a GCVWR of 14,000.
    If you're Tahoe weighs 7000lbs after you're all hitched up then to be with in the GCVWR you can only tow 7000lbs max.
    Whatever weight you add to the Tahoes base weight of 5595lbs comes off the towable weight.
  • kfballer22 wrote:
    Weight Information
    Your "curb" weights are highlighted in red.
    You need to add those together.. That gives you 5595 lbs for curb weight.
    Subtract 5595 from 7400 and you have 1805 lbs as your available payload.
    You will need to subtract you the driver, passengers, gear and fuel weight from that number above to get what is leftover for tongue weight.
    As I mentioned before dry weights seldom are what as advertised.. Typically you can add AT LEAST 500 lbs to the dry weight.. So a trailer listed as 5900 lbs dry will be around 6400 lbs empty..
    But keep in mind you seldom ever tow with a empty trailer.. EVERYTHING (and I mean EVERYTHING) you put into that trailer adds weight.. So you can figure that trailer when loaded is going to be 800 lbs to 1000 lbs heavier..
    That would now put your 5900 lb advertised dry weight at 7400 lbs.. That will translate into 740 lb - 1110 lbs tongue weight..
    Add 100lbs for WD and your tongue can be as high as 1210 lbs.
    Even though you may have 600 lbs of payload left I think you are going to be happier with a trailer dry weight of no more than 5K and less would be better yet..
    I am always puzzled at folks who feel the need to go as big and heavy as possible..
  • Yes, I would not want to tow a fully loaded trailer that exceeds 6000 with a Yukon. Simply my opinion.
  • Payload is something that should be on the Yellow Sticker inside the driver's door frame for your Denali. That number would be accurate for your specific build before you add anything other than a very modestly-sized driver (I believe 160lbs).
    Everything else you add to the vehicle along with the tongue weight of the TT count against this total.
    So if you come back with your Yellow Sticker Payload figure, folks can make more accurate suggestions about max trailer size/weight.
  • I did see where the rver above suggested that I shouldn't tow a vehicle above 6000lbs loaded. That would eliminate a trailer of 5900lbs. Am I accurate?
  • Weight Information
    Trailer "dry weights" are not real useful since they often do not include things like propane, propane tanks, battery and any optional add on items..
    A trailer with a dry weight of 6500 is more likely to be 7000-7200 lbs empty..
    I think you will find that trailer to be well over your capacity when you are loaded..
    But.. You really need to determine exactly what you CAN tow.. That towing capacity of 8000 lbs is seldom achievable because you typically run out of available payload of your vehicle.
    That 8000 lb tow rating comes from a stripped down BASE model of your vehicle.. Any options above that base model will take away available payload (your trailer tongue becomes payload for your vehicle and must be accounted for)..
    So, to determine the payload for your vehicle you need the GVWR of the vehicle and the curb weight (no passengers or personal gear) of the vehicle.
    Sometimes the curbweight is printed on the drivers door info and sometimes it is not. If not then you need to get the vehicle weighed..
    Many newer vehicles have a tire loading info sticker on the drivers side door or door post which will list the max payload.. If you have that you can use it instead of weighing the vehicle.
    Subtract the curb weight from the GVWR and the result is available payload..
    Passengers and personal gear weight is subtracted from the payload and the result is the MAX tongue weight your vehicle can haul..
    Tongue weight can vary from 10%-15% of the trailer weight and for best stability you should be shooting for 13%-15%..
    So a trailer at 6500 lbs EMPTY should have a tongue weight of 600 lbs to 975 lbs.. Loaded up your trailer is going to have a tongue weight well over 1000 lbs!
    Then you need to consider the WD (weight distribution hitch) weight as part of the payload of the vehicle since it will directly affect the vehicle payload.. That is at least 100 lbs worth of steel..
  • What is the "payload" capacity of the Yukon?
    Does it have "factory" tow package?
    Answering these questions first will lead you to the other answers.
  • An 8000 loaded trailer will have +/- 1000 lb tongue weight (always figure 13 percent ratio of trailer gvwr). What is the gvwr of your Yukon? How much weight will you be loading into the Yukon? Passengers, gear, dog, options, hitch, etc. When you add all together, you will more than likely overloading the Yukon. Manufacturers Tow capacities are deceiving. You run out of payload long before you reach max trailer weight the tow vehicle is rated to tow.
    P rated tires on the Yukon are soft and not a good fit for towing heavy trailers.
    If you want an 8000 lb trailer, I would get a larger tow vehicle. The max I would want to tow is 6000 lb trailer loaded.
    You will get a lot of opinions, but if you exceed any ratings including payload, your trailer is too heavy. BTW ignore what dealers say, they don't care about your safety.
