ksss
Feb 18, 2018Explorer
Cummins12V98 wrote:drsteve wrote:lawrosa wrote:
Man that thing is almost 9000 lbs...
There's the OP's answer concerning where the payload went. They used it up with bling.
Load carrying capacity and off road articulation don't belong together.
So why put it in a 3/4 ton chassis then? You cant tow with it like a regular 3/4 ton, you cant carry anything in it like a regular 3/4 ton and even with a front sway bar disconnect, a 3/4 is not going to articulate very well anyway (assuming a stiffer chassis). So it isn't as hard core as the Raptor, yet its compromised for use as a typical 3/4 ton pickup. At the end you have a 3/4 ton with half ton specs, marginally improved off road capability with a big motor, 4:10 rears and poor mpg. What are the compromises buying you? Where are the upsides? It attempts to be a Jack of all Trades and really succeeds none of them.
Maybe they should have put the package in a one ton so they could have netted a HD pickup with true 3/4 specs. At least then you could do something with it.
