BurbMan's avatar
BurbMan
Explorer II
Sep 28, 2015
What Do I need?
What would I need to tow this in the mountains in the northeast?
Dry Weight 15725lbs
GVWR 20000lbs
Cargo Capacity 4227lbs
Hitch Weight 3525lbs
Axle Weight 7000lbs
Exterior Height 13.25'
Exterior Length 44.00'
Exterior Width 8.42'
Interior Height N/A
Fresh Water 100gal
Black Water 80gal
Gray Water 69gal
  • I live in the Pocono Region. Local routes and secondary roads will kill a gasser. Trust me! I'm killing a 6.0 3.73 burb.
  • agesilaus wrote:
    A one ton dual rear axle diesel from any of the three Ford/GM/Dodge will work. And is a lot more practical than a MDT.
    When did the northeast grow mountains anyway? You don't mean those hills do you?
    Well, yes, they are hills. But climbing from Denver over the first mountain (5,000 feet to 11,000 feet) with a 6-7% grade all the way is not dissimilar from climbing many of the 6,000 foot mountains/hills in the east from near sea level, save that non-turbo engines are short more power for the pull at the higher altitudes.
    I just did that climb beyond Denver a couple weeks ago. Earlier this summer I climbed a 2,000 foot peak here in Virginia with a 15% grade. Either way, both are tough on the equipment.
    These are mountains
    These are hills
    X2
  • A one ton dual rear axle diesel from any of the three Ford/GM/Dodge will work. And is a lot more practical than a MDT.
    These are mountains
    These are hills
  • MDT ^^ that.
    What you 'need' vs. what you can get by with are two different things.
