burningman's avatar
burningman
Explorer II
Sep 14, 2019
What else does your truck do?
I’ve always thought part of the reason to have a truck camper is because you already have a truck anyway.
From reading here I’ve gotten the impression a lot of people buy a truck to do nothing but carry a camper.
Is that really common? Seems like a heck of an expensive way to have an RV!
Question Two is about the ol’ hot topic, payload rating numbers.
I understand trucks very thoroughly, it’s just a fundamental one; why is it that only camper hauling people are so concerned about payload sticker ratings, when it seems no one else is?
Here’s an example, one of my own pickups doing other work.
This is my Dodge dually with two 3000 pound sacks of 5/8-minus gravel in the back. On the scale the rear axle weighed right about 10,000 (that canopy is heavy too). That puts every tire below it’s rating and they’re only 235/85-16s. The Dana 80 axle has an 11,000 rating by Dana, In fact, F450 Fords used to use the very same Dana 60 front/Dana 80 rear combo. This truck has done this for 20 years. I pulled the rear hubs and bearings recently to have a look, they’re the originals and are in fine shape.
If you look at the so-called ratings for a ‘99 Dodge 3500, it says it can’t do this, yet it clearly can.
Where I work, one tons routinely haul this or more every day. I couid take lots of similar photos of others. Nobody using these trucks for work worries about it.
    Exactly..but the internet is addictive and has had me weigh my rig for the first time ever owning a pickup..Just because I saw it on the internet..It was kinda fun though playing on the scales again..
    A Class C makes way more sense if a guy is never going to use his pickup for anything but hauling a TC..
    I haul my Yamaha Rhino and mostly firewood in my pickup but use it sometimes to help move stuff or go to the dump..I have never been without a pickup ever until I went Class C and sold my 3/4 ton pickup..Huge mistake for me and my ways...Gotta have a pickup in this area..
    Sometimes I wonder about things I see here also,like buying one battery that cost more than a brand new Honda inverter generator or solar panels and all the stuff that goes with it that are very costly..
    Times and the internet has definitely changed the way people camp.They used to call camping roughing it,not anymore.."Laughing"
  • Well years back when we were TC users my trucks also had to pull heavy GN stock trailers...dot registered GN flatdeck trailers/GN/bumper pull enclosed trailers.....boat trailers.....haul hay.....deliver firewood.....normal farm and ranch stuff and loan them the kids/family because they didn't have a truck.
    My trucks did and still do double and triple duties although we don't have a TC at this time.
    Q#2...Having owned three different TC years ago I still look in on the TC forum to keep up with changes which are many. Most TC owners over here have a much better grasp of a trucks actual capabilities per mfg mechanical specs and understand how to find and read the vehicle mfg website sources that show the mechanical sameness or differences in each size truck.
    JMO but the 5th wheel and TT forums have the most payload sticker weight cop types mainly because many are newbs and have never owned a truck before so they bit into the payload sticker or trucks gross weight minus gvwr = payload numbers.....and completely ignore the fact that the new higher gvwr payload sticker numbers, in many cases, will and has exceeded a tire/wheel load or rear suspension ratings.
  • Long, long time ago (50 years) when I was building my house, I was in need of cement. Just so happened, my brother's son-in-law worked at a local cement plant. He called and told my brother they had had a spill and I could have as much of the spilled cement as I wanted. My brother had a 1953 1/4 ton Chevy pickup with a six banger, so off to the cement plant. We loaded 23 80 pound bags (around a ton) into the truck and off we went. The rear of the truck was very low and the front was pointing skyward. My brother remarked how the steering felt like power steering as we went the 5 miles to my place. Many years later, he sold the truck and it was still going strong.
  • IMO the “line” between hard use of your truck and abuse and between safe operation and endangering others is hard to determine. I choose to be safe and stay within specs. Ask your insurance agent what he/she thinks about overloading. At some point overloading becomes “reckless” (or “gross”) negligence and your insurance maximums won’t be enough.
  • My truck had a 45kw Onan in the back, along with 4 follow spotlights. Early 80s 350, 165 hp. I totaled 19,500 lbs, about 5,000 lbs over gcvw.
  • JMHO but I hear you. Bought my truck to haul gravel, fire wood, other stuff. Then bought a cheap 5th wheel, 18k gvwr. All the 5th wheel people said I had to buy a dually. Now I have an igloo 9.5, 3500 pounds wet ready to go. Over the scale I am 800 pounds over my gvwr but 30000 miles, no issues. Truck is registered for 12500 and front and rear axles are under as well as the tires but the "experts" still critique. Some people just have too much time. Go camping and ignore the noise.??
