mkletka
Jul 23, 2016Explorer
What happens when batteries are low in charge?
Forgive my ignorance. Trying to diagnose a problem. My outlets work fine when hooked up to shore power. Not when I switch to battery power. Same when I have the generator running. Is there a switch that needs to be moved when I am on generator or battery power? I have two knobs under the kitchen sink. They say "in", "on" above the switches and below the knows it says "out", "off". I'm assuming that this disconnects the batteries. When disconnected from shore power the level lights show my batteries only have half a charge. One battery is prob 5 years old and the other is unknown age.
Reading the info on the breaker panel it seems that the DC equipment works on battery power and the outlets must have converted power from the battery to work. If the batteries are not holding a full charge would that cause the outlets to be without power but the lights still work?
The air conditioner works on shore power but not when the generator is on. It's a 2.5 kw generator.
Could I hook my truck batteries up to my camper batteries to see if that makes a difference? I'm thinking disconnect the batteries in the camper and use my jumper cables to connect to the battery cables in the camper.
Any ideas would be welcome.
