Gdetrailer wrote:
Dutchmensport writes "Personally, as suggested above, I'd dump this camper and chock it up to bad experience and get something that is ready to go. You are going to invest a LOT more time and money into this camper than you can imagine. And then, if you decide to sell it, you will not get your investment back out ... not at all. Upgrades, fixes, cleanliness, improvements, do not add value to RV. The value is based on age, not your emotional or financial investment. "
DS - I've read your posts on how you have had to rebuild the interior of your NEW fifth wheel - doors not staying closed during transport, needing fridge mods to stop stuff from moving around underway - these from memory. I'm sure I could find some great quotes if I wanted to spend the time. So maybe you should - as you advised, dump it and find something ready to go.
Or you could simply use the knowledge you most likely gained to help a guy out, and stop being a reason for people to run from this forum.
Kudos to the OP for sticking to his guns.
