Hence's avatar
Hence
What is going on with this roof?
Hi we are new to travel trailers. And we just bought a 1986 roadranger that needed a little work.... so I thought. We have now realized that the roof has leaking, all the windows have leaking, the screws on the back right corner will not stay in because the wood is rotted and a bunch of the floor boards. Soooo we have a long road ahead of us. I was thinking we should start with the roof first, any opinions? The roof is aluminum and is in 3-4 sections. The roof vents were just replaced but sealed wrong so we will reseal them and check for water damage around them but Im not sure if there is leaking coming from any other spots. the seams look like a black substance was put down first, then someone caulked over that and then painted just the seams white. I think the seams need to be resealed should I scrape it clean and then apply enternabond tape? I am was going to use butyl tape and dicor self leveling lap sealant to do the air vents. Should I also do that with the other things sticking up on the roof? one other concern is should I coat the aluminum roof with anything?
  • Yes this is going to be longer than we thought but we are not afraid of tackling the wood rot. I just need to know what to do with the roof. Or should we start somewhere else first? But no matter what I need to know what to do with the roof.
  • Lwiddis wrote:
    “the roof has leaking, all the windows have leaking, the screws on the back right corner will not stay in because the wood is rotted and a bunch of the floor boards.“ And “roof vents were just replaced but sealed wrong so we will reseal them and check for water damage.”
    You want a project for a couple of years or do you want to go camping? If the latter, dump that TT, charge it off to a learning experience and buy another one that you inspect completely before buying.
    I'm in agreement. I think you're going to find yourself buried in repairing wood rot, and all that goes with it. Definitely a great learning experience, if nothing else. Best of luck!
  • “the roof has leaking, all the windows have leaking, the screws on the back right corner will not stay in because the wood is rotted and a bunch of the floor boards.“ And “roof vents were just replaced but sealed wrong so we will reseal them and check for water damage.”
