Timeking
Sep 07, 2015Explorer
To clarify, the wood framing is maybe inside the floor, not underneath the floor? The floor is one big assembly? The floor, top to bottom, is less than 2 inches thick. There is sheathing on the top and bottom of the foam, the bottom being covered by vapor barrier.
Do you think if I took a nail and hammer, and used as you would to find a stud behind drywall, I could find the framing? Do they typically run stuff through the composite panel like a gas line, and Kaboom?
44,056 PostsLatest Activity: Jan 12, 2020
