- nwjetboatExplorer2003 Quad cab, with AF990. Mods in signature. No issues.
- Sitting_BullExplorer III have a 2006 GMC Sierra 2500HD diesel and carry a 1998 Adventurer 10'. Dry weight on camper says 960KG or 2117lbs. The truck handles it very well when loaded up.
- exhaustipatedExplorer2009 Chevrolet Silverado 2500HD Ext Cab 4x4 Z71 6.0L V8 with a 2012 Travel Lite 960RX Ultra
- WheelholderExplorerWe have a lance 830 on an 08 c/c shortbed duramax/allison. Camper is right at 3200# ready to roll. Rides ok. Power is there to roll as fast as I care to.
Mods are Timbren SES (bigger bump stops) and the adjustable stabil loads. Upgraded the tires to Nitto 285/75-16 and rims to Gear alloy 8.5's. Carrying capacity is 3750# per tire. Am abot 6600# on rear of truck. - rbcampingExplorerThanks everybody.
My truck is a 2000 Dodge QCLB with 19.5 wheels and tires, level kit(springs), Traction bars, add a packs and overload camper springs, over sized sway-bar, bilstiens, 500 plus HP,3rd gen brakes, Allison 5speed transmission, and an exhaust brake.
I'm probably going to end up with a Eaglecap 995, although I would like the 1160. I'm pretty sure that the 1160 is really pushing it. Do you think I'll be OK with a 995? I have already had over 5000 in the bed.
I may be towing a 2000 lb. boat(with trailer) from time to time. - gmgagaExplorer2006 GMC 2500HD with 2012 Wolcreek 816. I had a local spring shop add a leaf to each pack. I also run Torklift Stable loads. This is my first camper and I feel that this set is pretty stable and rides great.
- nick11ExplorerAn 06 Af860 full wall slide on an 05 F250 4x4 CCSB with Procomp adjustable shocks, airbags and 3750lb tires - rides level and controlled
- FishnmagicianExplorer3800lb Lance, added air bags, sway bar, MonoMax shocks, and went up a size tire(265/75/16)
- DWeikertExplorer IINorthstar 8.5 Adventurer on a 2008 Chevy 2500HD Duramax/Allison. Upgraded tires to 3415 lb 265/75R16 and compatible wheels, KYB Monomax rear shocks, Hellwig sway bar and air bags.
- Reelescape1Explorer
