Huntindog
Feb 05, 2018Explorer
colliehauler wrote:X2 We have a winner!
You will never see a semi with the axles in the middle of a trailer. Most of the weight is over the drive axle, physics. This allows the best handling and stability. In the world of TT this is not always feasible it's a compromise between handling and not overloading the tow vehicle. That's the same reason 5th wheels will always handle better then a TT. More tongue weight will always produce better handling up to the point the tow vehicle is overloaded then it has a negative effect. The laws of physics don't change because you want it to.
There are some good reasons behind the 10-15% rule. 10% is the minimum for a safe tow.
15% is the limit for most equipment. TV, hitch,TT frame etc.
If your equipment is up to it, then there is no problem with exceeding 15%.
