gmw_photos
Feb 06, 2018Explorer
Just a note I forgot to include, my travel trailer in the above picture is around 580-600 tongue. The horse trailer is about 140 pounds more than that. With the horse trailer I have to crank the blue ox WD hitch tighter.
Both handle very well. Lots of miles with both.
As an aside comment, my experience the Frontier is a very much under-rated little truck. The 4.0L V6 makes good torque from 2800 to it's peak at 3900 and will pull a six percent grade, on cruise control at 60 mph, 3200 rpm. I tow in fourth gear ( six speed manual ). 150K miles, approx 50K miles towing. Original clutch.
No doubt the pay-low/poe-poe are about to go ballistic on me here, but that's ok. I know what works out here in the real world.
Back to the original point of the thread, I like to set up to around 12 to 15% tongue. If I had a trailer that was significantly higher than that, I'd move some weight to a position over the axles. Not behind the axles, but over the axles. Set up that way with a correctly adjust WD hitch, my experiences have been good.
I feel "too much" TW can cause the rear suspension of the truck to "bounce" too much as it is forced to stroke thru it's travel by the excessive weight.
