JBarca
Feb 06, 2018Nomad II
A point to bring to the discussion.
It has been mentioned that a semi trailer or a 5th wheel tows better than a conventional bumper pull trailer because they have high tongue weight. While both setups do have high TW or pin weight in this case, TW is not the largest factor involved on why those setups tow more stable.
Think about how those setups are made?
A gooseneck trailer is in this same category. And yes, in those 3 examples the words, trailer sway is about totally eliminated. But it is not the fact they have high TW.
A larger factor then the TW is the difference of the rear overhang of the tow ball behind the rear axle of the truck. On a semi, gooseneck or a 5th wheel, the distance from the truck rear axle to the trailer pivot point is very small. On a conventional TT using a bumper pull hitch, the rear overhang is very large. 50 to 65" is common.
Look here, this will help show the effect if you have ever seen the PullRite travel trailer hitch. http://www.pullrite.com/products/pullrite-worry-free-travel-trailer-towing
Here are some pics of from one of my very good friends Less Adams. He used this for a while on his F250 and his TT.
The pivot point is approx 6 to 8" behind the rear axle of the truck. Not 65" behind it if he was using a standard WD hitch.
The weight that the truck is holding from the TT is actually less when using the PullRite then a conventional WD hitch. This is due to the long tongue addition on the trailer. The actual TT tongue weight has not increased very much other then the raw weight of the Pullrite hitch that is connected to the ball coupler. Yet the camper tows with no sway. It is not the fact of high TW, it is the lack of rear overhang.
Think about it, TW has nothing to do with this situation when using a PullRite hitch. The same camper TW only changed a little but the truck rear overhang reduced a lot.
For a conventional TT, the PullRite is the best no sway hitch as it mechanically eliminates the root cause of the problem. Large rear overhang. Even this style trailer hitch needs proper TW to operate correctly, but it does not need high TW.
Hope this helps
John
Hope this helps
John
