- wing_zealotExplorer
Fisherguy wrote:
I didn't say "electric manual override", I said "electronic manual override". And it only makes sense if you own one and want to know what to do if it quits working. Starts on page 12 of the service manual.wing_zealot wrote:
If it's a schwintek slide system, it doesn't have a crank. It has an electronic manual override.
"Electric manual override", does that even make sense?"
Your trailer might not have one, our 2007 Komfort 274TS has 2 slides, the rear bedroom slide had a manual crank, the main front slide didn't, I put one in when I had the underbelly off to do some wiring.
The back one is on the side the door is on in the fiberglass wall, the front crank is in the frame right where the steps are.
Clicky. - FisherguyExplorer
The back one is on the side the door is on in the fiberglass wall, the front crank is in the frame right where the steps are. - wing_zealotExplorerIf it's a schwintek slide system, it doesn't have a crank. It has an electronic manual override.
- Edd505ExplorerMy old Jayco you could use a ratchet on a bolt under there.
- LwiddisNomad IIYou’ll need to get up close and personal (underneath) to find it.
- BarneySNomadSome have a hole in the side of the trailer for a crank. My trailer has a small crank that fits on a bolt under the trailer on the slide out motor or gear case. It has been a long time since I was under there so can't remember exactly. If you don't see a small hole, crawl under and look at the slide mechanism. You should find some way of turning the motor or shaft. Might be with just a wrench and not a special crank.
Barney
44,066 PostsLatest Activity: Apr 16, 2026
