fuelhauler's avatar
fuelhauler
where to put inverter Arctic Fox 990
Any of you install a small inverter to run tv & dvd player in your Arctic Fox 990? Looking for ideas for the best place & how to run the cables to the battery.
  • Mines under the plastic pull out bin that is inside the cabover step that you use to get into bed. I lifted out the bin and installed a 1000 watt Pro Sine wave inverter. I actually drilled some 1/2" holes in the bottom of the bin to help ventilate any heat from the inverter. Really dont think it was needed but I still did it. Also a nice place for using short cable runs to the batteries in my 1140.
