carringb
Jan 09, 2014Explorer
Wow, if this is the 2nd head gasket, that pretty says the head is defective. Either it's warped, or there's a scratch in the mating surface. I would not try another head gasket repair (assuming a correct diagnosis) without replacing the head. Good news is re-manufactured heads are under $400 loaded (meaning valves and cams and all that stuff is already installed).
Or, just swap with a wrecking-yard motor. They are cheap since that is such a common motor and failures are rare. If there's any sign of coolant in the oil, this is the way to go because even slight contamination can cause eventual bearing failure.
44,056 PostsLatest Activity: Jan 12, 2020
