lawrosa
Mar 01, 2018Explorer
bowler1 wrote:
Hi,
I am looking to get a one ton diesel SRW truck to tow a fairly heavy fifth wheel. I need one that will have sufficient payload to safely tow a trailer with a 2500 pound pin weight plus cargo, etc. and I really don't want to get a dually if I can avoid it.
I am looking for a long bed with a trim package equivalent to the Lariat, Laramie, etc.
Which of the Big Three has the highest payload rating? I would think that they would be fairly close but...
From what I have found so far in researching just Ford and Dodge it seems that an equivalently equipped long bed diesel in the high end trim package that the Ford has about 3200 pounds of payload but the Dodge has about 4200. Can this be right? That seems like a huge discrepency. Am I missing something here?
How does the Chevy compare?
thanks
Matt
You should have no problem, but we need more info. 2wd or 4 wd? Crew cab, reg, double cab?
Chevy silverado LTZ package 4WD crew cab long bed
truck in a 6.6 diesel has 3843 lb max payload..
15000 lbs 5th wheel towing 3:73 rear option only..
2WD
3993 lb payload 17400 lb 5th wheel towing
I like chevys...
