Me_Again
Mar 04, 2018Explorer III
Huntindog wrote:Me Again wrote:I have already looked. MY 2011 sticker is 100% silver with black print... And as an aside my axle weights add up to more than the GVWR, by quite a bit. GVWR is 13K. Axle ratings total over 15K.... GM COULD have put 14K as the GVWR and stayed in the same classification... They chose not to.
BTW all recently produced vehicles and traikers have a carrying capacity sticker that is the GVWR minus the actual weight as manufactured. This sticker is yellow or the part with this info is yellow. Look again.
There must be a reason for that.
Your door placard does not contain this info?
https://www.google.com/imgres?imgurl=http://www.tirerack.com/images/tires/tiretech/checking_tire_press/placard_detail.jpg&imgrefurl=https://tires.tirerack.com/tires/Recommended%20Tire%20Pressure&h=218&w=600&tbnid=l33XGhHvWZQJHM&tbnh=135&tbnw=373&usg=__EPtYTOupwWMogrnHwC-IBZyA26U=&docid=ZdAt41aNMx4soM#h=218&imgdii=TsWONOYJJicB3M:&tbnh=135&tbnw=373&w=600
