Huntindog
Mar 04, 2018Explorer
Me Again wrote:Your link goes directly to a sticker that has some yellow. But the only info on that sticker is basically tire info. No GVWR at all. Also no front or rear axle ratings. Simply tire size, and pressures. But your link has many pics to look at. Some of them show the silver sticker like I have. The silver stickers have much more info on them that pertains to this conversation. GVWR AND individual axle ratings. None of the yellow ones I clicked on show anything other than tire size, pressures and what the maximum cargo should be.Huntindog wrote:Me Again wrote:I have already looked. MY 2011 sticker is 100% silver with black print... And as an aside my axle weights add up to more than the GVWR, by quite a bit. GVWR is 13K. Axle ratings total over 15K.... GM COULD have put 14K as the GVWR and stayed in the same classification... They chose not to.
BTW all recently produced vehicles and traikers have a carrying capacity sticker that is the GVWR minus the actual weight as manufactured. This sticker is yellow or the part with this info is yellow. Look again.
There must be a reason for that.
Your door placard does not contain this info?
https://www.google.com/imgres?imgurl=http://www.tirerack.com/images/tires/tiretech/checking_tire_press/placard_detail.jpg&imgrefurl=https://tires.tirerack.com/tires/Recommended%20Tire%20Pressure&h=218&w=600&tbnid=l33XGhHvWZQJHM&tbnh=135&tbnw=373&usg=__EPtYTOupwWMogrnHwC-IBZyA26U=&docid=ZdAt41aNMx4soM#h=218&imgdii=TsWONOYJJicB3M:&tbnh=135&tbnw=373&w=600
Thank you for posting that. It is not often that someone I am having a debate with posts a link that proves what I am saying. Usually they just sit back and demand that I prove it.
I appreciate your effort.:B
