Danattherock
Aug 25, 2015Explorer
Will do Jim. Thanks man. ^^^^
Thank you. You bring up many variables I need to start comparing. Within Forest River, I have found three 29' trailers that are essentially the same layout. Minor differences in dry and hitch weight. Will be sure to add the above considerations to my comparison. Appreciate you taking the time to suggest that.
And thanks for all the other replies. Will continue researching them all individually. Got caught up on Forest River site for a few hours. Had no idea they had so many product lines. Thanks to the gentlemen earlier that suggested the lighter near identical offering. Will follow up on that, and the third on Forest Rivers website. Our plan is to pick the one among the three we like best, if there is a standout, and locate one in person to view.
Appreciate the help guys and gals.
Dan
Need-A-Vacation wrote:
Few other things to compare:
Furnace and a/c size.
Tank sizes: Fresh, gray, and black tanks. Most will have a very similar sized hot water heater and tank. Some may be gas only, or also electirc (saves propane). Some also have electronic ignition.
Fridge size.
Wheel/tire size. Some may have 14" wheels, some 15". Very few 14" tires, and may not be able to get a higher weight rating for more reserve capacity.
Propane tank size.
Factory matresses.
Dan
