Buzzcut1
Dec 10, 2019Nomad II
I leave my lance plugged in while not in use that way the batteries are always charged and the fridge is always cold ( I store extra beer in there).
Yes the batteries should charge while driving if the wiring is hooked up correctly. Make sure you have an automatic interrupt in the circuit so that when the truck is turned off the camper cannot draw down the truck batteries
My lance has no thermostat on the hot water heater. I have never worried about it in ten years,
traveling. Fridge runs on propane, I only turn it off at gas staions before pulling in unless I am filling in the truck area at a truck stop ( only diesel at the pumps so no fire danger from the flame) In very cold temps I will drive with the furnace on to keep the camper water pipes from freezing otherwise its off.
