valhalla360 wrote:
noteven wrote:
Because it is MOAR! speeds?
10 speeds and more are needed to optimize gas engines.
Why not use them in diesels too? Diesels don’t care.
While both types benefit...
Actually, the other way around, gas engines are happier over a wider range of RPM. If the engine is happy between say 1800-3500rpm, you can space the gears out more than if the engine is happy over 1500-2500rpm.
Of course really with modern engines, the power output is so great we are talking incremental improvements. Probably the biggest benefit is not having to mess around with a deep rear axle ratio for all but the heaviest trailers. It used to be a choice between good towing performance vs non-towing performance if you wanted to run in top gear. With 8-10 gears, the rear axle ratio is far less important and the truck will simply select the gear ratio it needs based on loading and speed.
I don't know much about little diesels, but I know all diesel do not have equal power bands. 318 hp Detroit & 13speed. Best performance, slam hand in door, keep it wide open. Tach drops below 1800? drop a gear, but it back to 2150. 300 HP Mack, 5 speed? Same load, 4:17 instead of 4:44 rear. Pull her down to 1200, neutral to wind her up to 2100 to put back in gear. NTC Cummins, 335 hp 13 & 4:44? Near same power band as Detroit except higher HP and torque. Would stay with Mack, but worked driver more. And if you wanted to hammer west across Kansas, better watch the Pyro or will burn hole in piston.
My experience tells me that more speeds in trans would only help if the engine could be tuned for better power/economy in a narrow band. And adding OD gears allows you to keep the lower speed rearend. And higher speed rears put more strain on everything but the axle shaft when starting a load.
